It is currently Fri Jul 18, 2025 2:07 am
Post new topic Reply to topic  [ 34 posts ]  Go to page Previous  1, 2
PostPosted: Sun Jan 15, 2006 2:47 pm
First name: Scott
Last Name: Thompson
Great, I've been sticking one of those syringes in my mouth to irrigate after wisdom tooth extraction
And no wise cracks about not knowing one end from the other.
Scott Thompson
Port Townsend,WA
-Billy Bragg
PostPosted: Sun Jan 15, 2006 3:12 pm
[QUOTE=Scott Thompson] Great, I've been sticking one of those syringes in my mouth to irrigate after wisdom tooth extraction
Rolling on the floor, Scott, you made my day!
PostPosted: Sun Jan 15, 2006 3:54 pm
Mn! i've got to change underwear!
PostPosted: Sun Jan 15, 2006 4:08 pm
Hmmm...
When I was learning to use hhg I was told to clamp for two hours. OTOH, we also did 'rub' joints for violin backs and tops with no clamps at all, but you had to leave them untouched for at least 2 hrs wile the glue did the clamping. I have gotten full wood breakage on a spruce test sample of a rub joint in only about 15 minutes, but still stay with the 2 hr limit I was taught.
PostPosted: Sun Jan 15, 2006 4:23 pm
I clamp and leave untouched for 1 hour normally. So far so good, but better safe than sorry as they say.
PostPosted: Sun Jan 15, 2006 4:24 pm
Thank you Mr Carruth,
to practice with HHG, In your opinion, do you think that the use of a sort of dummy sound box made of plywood would help as well as dry runs before applying it to good wood? I know some veterans here, especially Mario and Brock have said to do my second guitar top with Titebond but my thinking on it is this: if hhg is so scary and is part of a luthier's daily routine, why shouldn't i get accustomed to it right away on a dummy soundbox or two so i get that stupid fear out of the way?
Thank you sir for all your input in advance
Regards
PostPosted: Sun Jan 15, 2006 5:10 pm
[QUOTE=Alan Carruth] we also did 'rub' joints for violin backs and tops with no clamps at all [/QUOTE]
It's the original vacuum clamp!
PostPosted: Sun Jan 15, 2006 7:54 pm
[QUOTE=Serge Poirier] Thank you Mr Carruth,
Regards
Serge[/QUOTE]
Hide glue's the ultimate reversible glue, though; as Mario said upthread, a dry run or four, then try with the hot hide, and if it doesn't go quickly enough/well enough, pull it apart, clean up, try again. Seems like a whole lot less work than building a dummy soundbox for this purpose.Mattia Valente38733.1636111111
PostPosted: Sun Jan 15, 2006 11:14 pm
Thanks A lot Mattia,
When building my first, i used yellow carpenter's glue and mistakes i made are stuck in it.! Now, i want to do it differently and use the right stuff. I'll remember that part of the HHG being reversible though. And i copied the thread where Mario explains his routine. I promised myself that my second and third guitars will be 10 times better than the first and i'm ready to do what's best since it's going to be a gift for loved ones.
I'm going for it, wish me luck!
